Integrated
Bindery Systems
British Engineering logo
Link to IBIS LinkedIn page
Book stacker BSS-30 allows non-stop Smart-binder operation
Allows non-stop Smart-binder operation
The BSS-30 book stacker allows non-stop Smart-binder operation without the need for the operator to continually have to remove books from the delivery conveyor. Books pass through the standard Smart-binder delivery conveyor into the BSS-30 stacker where they collect into piles up to 160 mm high. The number of books in each pile is selectable by the machine operator.
Book piles are delivered onto a roller table where they accumulate until removed by the operator. In-line (or off-line) pile ‘banding is also available.
IBIS BSS-30 booklet stacker
Booklet stack
delivery
Booklet entry
from SB delivery
30‑booklet stacker
Completed stacks contain booklets (or signatures) with spines all orientated in the same direction.
An alternative version of this stacker is available with an additional automatic stack reject facility. This ejects any bad stacks in one direction (stacks which do not contain the correct booklets of signatures in the correct sequence) and delivers all good stacks in a different direction. This version stacker includes a code reader to read incoming booklets or signatures.
If making book blocks for perfect binding, then a cold glue applicator may be added which glues the signatures inside each book block. This may be used to aid the transportation of these book blocks into a perfect binder.
BSS-30 stacker specifications
Two versions available with different widths
Swipe columns to left to view all the table.
Formate Infeed width Infeed length
Alpha 500plus min
1 up max
2 up max (optional)
3 up max (optional)
80mm (3 1/4")
510mm (20")
235mm (9 1/4")
150mm (6")
95mm (3 3/4")
330mm(13")
330mm(13")
330mm(13")
Alpha 700plus min
1 up max
2 up max (optional)
3 up max (optional)
4 up max (optional)
80mm (3 1/4")
760mm (30")
350mm (13 3/4")
235mm (9 1/4")
155mm
95mm (3 3/4")
330mm(13")
330mm(13")
330mm(13")
330mm(13")
Max stack height 160mm
Min stack height 3mm
Speeds 15 - 205 m/min
Performance 900 stacks per hour per up-work
Electrical connection 16A, 400/230v, 3.5kw
Compressed air consumption * 100l/min net, 6bar (with air blast device 250 l/min). Dry filtered air on site
* Note: Re Compressed air consumption: Signal connection is MBO 24 pin as standard.
BSS-30 Floorplan
Showing optional stack reject lane.
(Stacker may be on the left as shown below, or on the right)
BSS-30 stacker floorplan
Alternative delivery
for good stacks
Good
stacks
Stack
reject
Booklet infeed
from SB delivery
conveyor
BSS‑30 floorplan
BSS-30 with optional stack reject
(With delivery on the right as shown below, or on the left)
Rejected stack
delivery
Good stack delivery
Alternative direction
for good stack
delivery
Optional stack reject
The above image shows good books being delivered ‘head leading’ , but an alternative configuration can deliver good books in a different direction if preferred.
