Flow diagram: A4 production, 450 mm web
The circa 450 mm web is cut into sheets 450 x 307mm. These 4-page sheets enter the Smart-binder (SB) infeed and the bar code on each sheet is read. Each sheet is accurately side-registered and the Smart-binder plow-folds each sheet down the center. ISG cold glue may be applied along the inside of each folded sheet (SB-3 only) and the sheets collect together on top of each other on the saddle (max approx 50 sheets, 200 pages, depending on paper weight).
If a separately-fed cover is needed this will feed automatically from the optional cover feeder CIF-102 and is folded on top of the inside sheets. Sheets are wire-stitched (if stitching is required) and 3-side trimmed to A4 size. Booklets may be stacked on the optional BSS-10 if required.
Recommended maximum sheet feed rate 400 sheets/min (depending on paper weight and other variables)
Printed 4-page sheets size circa 450 x 307mm are loaded into the SB-095 (or SB-097) sheet pile-feeder and fed into the SB at sheet feed rates up to 400 sheets/min and the Smart-binder plow-folds each sheet down the center. ISG cold glue may be applied (SB-3 only) and the folded sheets collect together on top of each other on the saddle (max approx 50 sheets, 200 pages, depending on paper weight). If a separately-fed cover is needed this will feed automatically from the optional cover feeder CIF-102 and is folded on top of the inside sheets.
The sheets (and optional cover) are wire-stitched (if stitching is required), 3-side trimmed to A4 size and delivered in a shingled stream onto an indexing delivery conveyor. Booklets may be stacked using the optional BSS-10 stacker if required.
The SB-096 sheet feeder may be used together with either the SB-095 or SB-097 to side feed additional sheets into the flow
Flow diagram: Off-line A4 booklet production
The circa 450 mm web is cut into sheets circa 450 x 614mm. These 8-page sheets enter the F-100 buckle folder and are buckle-folded in half (to a 307mm length) and enter the SB.
Flow-diagram: A4 production, 450 (or 440)mm web with F‑100 folder
Total number of pages in the finished booklet (excluding a separately-fed cover sheet) must be divisible by 8
The circa 450 mm web is cut into sheets with a length of either 614mm (8 pages per sheet) or 921mm (12 pages per sheet). These sheets are buckled folded by the F-200 either once or twice to 307mm length before they enter the Smart-binder.
Flow-diagram: A4 production, circa 450 mm web with F‑200 folder (diagram shows a 12 page sheet)
By making booklets using multiple 8 page sheets followed by one 12 page sheet it is possible for the total number of pages in the finished booklet to be divisible by four (for example a booklet with 28 pages can be produced using two 8 page sheets then one 12 page sheet).
